smoking engine agane
In the van
A van
Over 25 year's
hi my engine has started smoking agene was wondering
could this be
(1) the fuel filter
(2) timing moved
it is tagging a bit of cranking to get it going
bill
Hi Bill
Could it be compression ?
Did you check after the rebuild ?
Good luck.................
Glad it was nothing serious.
the cranking problem the non return valve on the lift pump had a bit of crap in it so fuel was draining back and system was not staying pressurised I have put additional NRV in system now
was a bit wored as were going down to Lympstone Devon at the weekend for a wedding friend of mine his son is getting marred driving down Friday night
drive back Sunday night over night
Hi Bill
Compression is not a problem it's been starting with out hater plugs Frome could from the rebuild it's sorted now:BigGrin:
It could be water in the fuel pump, have you checked the nrv in the fuel line? ;)
That's what was cussing depressurisation of the system fixed it now but no water in to fuel pump I know of.
bill
