small crack on my window
Autotrail Savannah
I have a small crack on my window in the lounge area of my motorhome. Would superglue seal the crack and stop it from spreading or make the problem worse.
It wouldn't make it worse but it wouldn't stop the crack from continuing it's journey across the window.
If you can, put a piece of sellotape at what you surmise as the end of the crack and then carefully, using as little pressure as possible with the smallest drill bit, drill a hole through the place you have identified.
Remove the tape and then put some super glue on the highest part of the crack, being ready to wipe up residue.
Good luck.
I would wait for someone with more knowledge to weigh in, but I think you probably want a clear acrylic cement rather than superglue.
Edit: Tensol12 maybe?
You have to be VERY careful with a " Creeping Crack " 😁
  • Funny
Reactions: f6c
