Sikaflex Pre Treatment
Worcestershire
Burstner Elegance
What is it and should I bother?
I’m going to use Sikaflex 291i to bond two box section aluminium 6ft lengths to my vans roof and I heard about a pre treatment that can be used. Yes? No?
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
The activator for 291i is expensive I think £30 and if you read the blurb it says "may improve adhesion" I've never used it and never had any problems.
For a small job a £30 activator may be an unnecessary expense if the rest of your prep is spot on.
Because we do so many panels we use it anyway but do other prep which in our view is more important. Thorough cleaning, scuffing the surface, bone dry … no worries
jollyrodger
Devon/Cornwall
Sprinter 416 Auto
Since 1968'ish
I've used 291i a good few times (it goes off very quick) flows better if tube left in hot water prior to use.
Never used activator ,but cleaned surfaces with acetone prior to use .
A few vans still going around with rooves (roof's 🤔) still on.
Sikaflex 522 may be better for your needs
Wantage, UK
When we spoke to Sikaflex they said 552 was what we should use for mounting panels.
A
Worcestershire
Burstner Elegance
I’ve got some degreasing body shop panel wipe that I was going to use. I’ve previously used it before sticking various other things down and it’s been ok. I’ll slightly roughen the area too before I stick anything down. (y)
Gloucestershire, UK
Burstner Eliseo C602
Since 2016
I see Sika have a "newer" (?) version now - 554 which is described as a 'mounting adhesive'.
Sika Mounting Adhesive - Sikaflex-554 Black - Ideal for Large Components and High Dynamic Load - Ageing and Weather Resistant - 300 ml https://www.amazon.co.uk/dp/B09N7FFXS7
Not used it as already fitted a PV panel fitted with 291i.
A
Worcestershire
Burstner Elegance
I’ve just ordered a 3 pack of white 554 to go with the 3 pack of 291i I got yesterday! :LOL: You can never have too much Sikaflex! (y)
Oh and that’s in addition to 2 tubes of white EBT+ and a tube of black EBT+!
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
I used it but to be honest I don't think it's necessary. A decent roughing up of the surfaces and clean with a spirit should suffice
jollyrodger
Devon/Cornwall
Sprinter 416 Auto
Since 1968'ish
Have fun with the black, a little goes a long way if you don't watch out 🤣
Ask me how I know 🤣
A
Worcestershire
Burstner Elegance
So, how long does Sikaflex 554 need to “ set “ well enough to be able to drive?
The underside of the aluminium bar has been roughened with 60 grit and the van roof will also be slightly roughened and both thoroughly cleaned with panel wipe before a nice thick slab of 554 applied ( 3mm - 4mm ).
Is a week long enough?
Lenny HB
On the coast in West Sussex
Carthago Compactline
file:///C:/Users/User/Downloads/sikaflex-554.pdf
A
Worcestershire
Burstner Elegance
Well the aluminium beams stayed stuck on just fine for the last month bouncing and crashing around the highlands. (y)
York
Carthago 143
Learning
Nice job. We use Sika & Dow Corning to secure glass weighing several hundreds of kilo on to aluminium profiles, 20 floors up. The forces are massive, the contact surface would usually be anodised aluminium, which has been kept away from any contamination, never with a rough surface and I've not heard of a failure. If done correctly you could lift the van before the bond would break.
