Side Marker Lights
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
Hi all. We have a 2019 Elddis Magnum GT 185 on a Peugeot chassis with a lighting problem ☹️. The near side side marker lights & n/s rear high level marker lights aren’t working. I’ve checked all the fuses I can find, with a multi meter, in the cab on the rhs under the steering wheel, the fuses in the habitation area but all are ok. Does anyone know if there are any more hiding somewhere that I missed? Tearing my hair out here 🤣. Thanks in advance for any help.
If you have habitation seating behind the drivers seat it could also be worth a look under them for the marker light fuse module, (if you have not already looked there , it may look like item 1000244 at www.primaleisure.com).
Possibly the marker lights are powered via the vans ecu. If so and you have a fault with any light on the system the canbus system will remove the power from the circuit completely. So that one single failed light or wire will cause a complete outage.
This is how it is on my older van.
Oh don’t we just love unnecessary electronics, perfect for making life easy😳
Ninovan I had the same problem after a blown bulb, on mine there was no fuse as it was controlled by the Canbus. I disconnected the battery and left it for a few minutes which reset it. You will need to isolate any solar going into the cab battery also.
Thanks very much for that Diabalo. Sound like a plan & definitely worth a try. Won’t get a chance today so try it tomorrow. Bring back my first car, Moggy Minor 🤣. So easy 🤣
