Side marker light on Bailey Autograph
Bailey
Has anyone changed one of the middle marker lights? I have one that's failed but the cabling appears to be in what is effectively a trunking behind the skirt meaning I can't get to the connectors. The cabling is tight as trying to pull the crimp joints through the hole resulted in them disconnecting but obviously the other ends are now in a position that I can't get to them.
This can't be right surely, or am I missing something very obvious to everyone but me?
Thanks in anticipation of lowering my frustration.
When I had to replace the trim piece under the habitation door on 68-2 I seem to remember that one of the adjacent skirt pieces got dislodged during removal. It was a press fit onto a plastic extrusion behind that ran along the body, and pressed back into place with a good thump.
Not sure what model you’ve got but you may be able to loosen the skirt by trying to pull or prise the middle of it out away from the body. This might then allow you to move along and start prising more out until you reach the part with the light.
A photo might help showing the trim relative to the other mouldings?
Sorry, should have added that I suggested starting in the middle as the two ends are likely to be trapped under the habitation door trim panel and the wheel arch trim panel
