Maybe not in a Boxer PVC or else you will not be able to stand up in it.I guess I could make a suitable void as I haven't installed the shower tray yet.
I was thinking I could make a space under the floor if necessary, rather than raise the tray height.Maybe not in a Boxer PVC or else you will not be able to stand up in it.
I was just about to say the same. It's going to be pretty wiffy without a trapIf you don’t have a trap the smell from the waste tank can be overwhelming on occasions, are you having a tank..?
its a domestic shower waste a sink one would have a plug recessThat's a domestic sink waste. What sort of shower tray are you fitting?
Good point, I didn't notice tha lack of recess. You would need a big space below the tray to fit a trap onto that though, usually shower wastes are quite shallow with integrated traps and side exit fittings.its a domestic shower waste a sink one would have a plug recess
To me it looks like a domestic sink slotted waste. The slotted is used for built in overflow, in the ceramic sinks. This would be wrong for a shower tray, unless the outlet is so deep that covers the slot.its a domestic shower waste a sink one would have a plug recess
You can get adapters for washing machine and dishwashers that usually go under sink with 1 1/2 tread to a 22mm spigot. Make sure you use a un slotted waste. The one in the picture is slotted, and will leak out.How would I go about connecting a waste like this:-
to a hose like this:
without using a trap in-between?
There are 2 trains if thought on this issue, if you make a space between the showertray and the floor if the van and something breaks or gets blocked in the future then you may have to rip you shower tray out to fix, and whilst using shower, you may get water backing up or filling tray because of sheer volume of water. If, on the other hand you consider having the waste pipe dropping vertically down through flooring to underside of van, and have trap fitted then it’s a much easier job to work on any blockages and the water runs straight down through the floors keeping the tray emptier. Either way it’s worth speaking to Magnum Motorhomes for any bits.I was thinking I could make a space under the floor if necessary, rather than raise the tray height.
I'm considering thisThat's a domestic sink waste. What sort of shower tray are you fitting?
Motorhomes don't have waste traps.I was just about to say the same. It's going to be pretty wiffy without a trap
I'm pretty sure ours does built into the fitting under the sinkMotorhomes don't have waste traps.
They're not a trap as such, they have a slightly deeper flat bottom to hopefully catch any none fluid waste - food, hair etc. They don't stop any odours returning from the holding tank or the pipes as they don't fill with water as this water would begin to smell too.I'm pretty sure ours does built into the fitting under the sink
https://vi.raptor.ebaydesc.com/ws/e...1&pm=1&ds=0&t=1669314347000&ver=0&cspheader=1.
This is the waste on ours we have a chausson MH but got a waste like this when the original broke
