Shower valve
Portishead. Bristol
carthago C line 2018
Hi all thinking when I get back from Spain I might put a shower valve in the garage on my Carthago 2018 slimline Any recommendations on which Valve would be best. Ta.
depends what system you have if your taps use microswitches you stuck with motorhome stuff unless you add a switch if your pump is pressure switched then you can use domestic mixers
That is very helpful I had forgot if they are micro switched I don’t think they are. Is there a easy way to see. Thanks
We have this type in our garage,you will need to find a suitable place to mount it where you can get to the other side of the wall for the supply and fastenings.
Hose and trigger shower head extra!
I fitted one of these to the outside of our moho. The external flap even matched the existing BBQ and water fill points!
