If you don’t have the skills it doesn’t matter what tools you buy, you won’t be able to use them.
If you do have the skills you wouldn’t need to ask the question.
I have I think most electrical tools, built a stereo from scratch, also various wood working tools though most are things like hand saws. Want to avoid buying anything that is not going to get used enough and anything that will improve efficiency, probably have the skill to do a reasonable job.If funds permit, a plunge saw would be better than a standard circular saw. It allows more accurate cuts to be done more easily and quickly and with a better finish and less tear out. A good power drill with range of hole saws will be needed and many find that an oscillating multi tool becomes indispensable. They are great for work in confined spaces and for cutting square holes.
When you move onto electrics, a test meter and various sizes of crimping tool will be your friends.
Buy a good quality Multi-tool as with that you can do most things.I have I think most electrical tools, built a stereo from scratch, also various wood working tools though most are things like hand saws. Want to avoid buying anything that is not going to get used enough and anything that will improve efficiency, probably have the skill to do a reasonable job.
