- Jun 30, 2022
- 676
- 4,154
- burstner lyseo 590
- March 2022
Does anyone know where the temperature sensor is on a Butstner 590? We have an error message on our truma #621
As above and it simply pull's out. Check that it's still connectedDoes anyone know where the temperature sensor is on a Butstner 590? We have an error message on our truma #621
You should be able to test it with a multimeter. I'm guessing It's only a temperature sensitive switch that makes and break. Test it for continuity?
not switches any more it will be a temperature sensitive thermistor which changes resistance with temperature you can test with a multimeter on ohms as it gets hotter the resistance will usually drop some rise but rarely nowYou should be able to test it with a multimeter. I'm guessing It's only a temperature sensitive switch that makes and break. Test it for continuity?
New one here -
Caravan/Motorhome Truma 3002 Room Temperature Stat 4052816007052 | eBay
Find many great new & used options and get the best deals for Caravan/Motorhome Truma 3002 Room Temperature Stat at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
I wouldn't expect it to have any effect on the hot water???
