Hi all, a question about Semi air suspension on the rear of our motorhome, with a compressor how high will it lift the rear end to get up a steep driveway, as without it, it will bottom out, or any other ideas, thanks
Depends on a few things but if you have enough overhang behind rear wheels that you already ground out it should help. But it depends on vehicle type also, some transits havent seen much lift when fitted. Also the design of the actual bag will determin the amout of lift.Hi all, a question about Semi air suspension on the rear of our motorhome, with a compressor how high will it lift the rear end to get up a steep driveway, as without it, it will bottom out, or any other ideas, thanks
Our coachbuilt, but slightly longer [6.90mt] gives us about 70mm lift under the back end. Your's being slightly shorter [6.4Mt] will probably still give you in excess of 50mm fully inflated [ 5 Bar, or so]. Better softened off for normal use though[ between 2 - 3 bar].Hi all, a question about Semi air suspension on the rear of our motorhome, with a compressor how high will it lift the rear end to get up a steep driveway, as without it, it will bottom out, or any other ideas, thanks
