Self levelling system (32 Viewers)
Sep 29, 2024
knaus
Hi all , I have a motorhome with a hydraulic levelling system fitted which you level manually only via a control box , my question is can this be adapted to be auto self levelling and does anyone know where the electronics can be purchased.
M
Jun 21, 2018
491
1,606
Habrough ,N E Lincolnshire
Auto Trail Comanche
Since 2010
Welcome to Fun
I dont have an answer to your question but it would help others to try to advise you if you detailed the name of the system you have and photos would also be beneficial
M
Sep 29, 2024
knaus
Ye , not sure of the make but the system as a 8 port hydraulic valve system with a solenoid on each valve 12v so would think the electronics would be the same on most self levelling units sending a signal to each ram to go up and down according to the box with the level sensor.
Sep 17, 2017
6,253
11,969
Birmingham, UK
A-Class
I assume there's also some limit switches too detect when it's fully retracted or maybe even something that tells it how far out the legs are? The automated systems also tie into the ignition for safety. I suspect it's a lot more complex than just a level sensor.
