Yes if you use a front wheel chock like the one above the scooter will stand up while you tie it down, I then use 4 straps onto tie downs in the floor two go around the handlebars and down and two around the rear grab handles and down you need to get at least the rear straps at an angle to stop it moving side to side.I am looking to carry a scooter in the garage, but unsure how to secure, if wheeled into the garage and the wheel chock, will that hold the scooter securely whilst strapping down? Also how much strapping is required? I was thinking I would probably reverse the scooter in, then use "canyon dancer" handlebar fixings, will this be enough?
Should the scooter be on its stand for, either side or centre?
My front wheel is in the chock but no reason why you couldn't use it for the rear wheel except your steering of the scooter into position might be a little more difficult, I have not bothered fastening our chock down as once the wheel is in and the straps on it 'ain't going nowhere"Thanks guys, we will reverse the bike in and chock the rear, as one side of the garage is full height, so that will take the handlebars or screen, I assume then you don't use the stand? Also how is the wheel clamp fitted, do you bolt it through the garage floor? Sorry lots of questions but don't want the bike toppling over and getting damaged, or punching a hole through the walls.
I bolted it through the floor and spread the load below with a 10mm thick ali strip.Thanks guys, we will reverse the bike in and chock the rear, as one side of the garage is full height, so that will take the handlebars or screen, I assume then you don't use the stand? Also how is the wheel clamp fitted, do you bolt it through the garage floor? Sorry lots of questions but don't want the bike toppling over and getting damaged, or punching a hole through the walls.
Enough for 2 bikes then!And a 450kg loading WH
If you are drilling holes and not sealing them properly, they may not like it, but what else it the garage for ?I am considering buying a Chausson 628 but having trouble getting confirmation from the dealer whether or not carrying a scooter in the garage is acceptable and will not invalidate the warranty with Chausson. Any advice would be welcome.
A big part of the equation is wether you are going to take the mirrors off the scooter to get it in the garage, then of course its down to payload, check the height of your scoot with or without mirrors and then check the spec of the van that you like the looks of.Thanks for all the useful advice as still getting to grips with securing the scooter. However we are in the early stages of carrying a scooter in a garage rather than what we currently do which is to use a scooter trailer. It’s mind blowing how many different motorhomes are available but would welcome any advice regarding manufacturers that produce MH,s with garages suitable for carrying a scooter.( currently Honda lead) ideally want a low profile non A class.
