Have you checked that you have enough spare payload to carry a scooter and rack?
Plus the rear axle will stand the extra weight.
Agreed. It's a big van at 8m. Looks like it's normally plated at 3850kg, but only has a little over 500kg payload. A scooter and rack a long way behind the rear axle will eat a large chunk of that small payload. And probably add 200kg to the rear axle.Have you checked that you have enough spare payload to carry a scooter and rack?
The bike is 105kg we are very light travelers too.
Is it the 597 in the middle with 3,850 total and 2,000 on the back ?Yes I have checked and it’s good.
Am I correct it saying I can get it uplifted?Agreed. It's a big van at 8m. Looks like it's normally plated at 3850kg, but only has a little over 500kg payload. A scooter and rack a long way behind the rear axle will eat a large chunk of that small payload. And probably add 200kg to the rear axle.
Thanks for the info, I’ve contacted sv currently waiting for the outcome. Unfortunately I bought the bike last week and now I’m having to deal with it. If I have to change the tyres and get air suspension then so be it. I appreciate your help.Just be aware that a 105kg bike will not add 105 to the axle weight.. Because of the cantilever effect more like 140 plus the weight of the rack.
You can get the van uprated by contacting Van weight engineering or SV tech but sometimes that does not give you any extra on the rear axle, thats something to check first. Plus may need air suspension fitting and/or heavier rated tyres.
Research first before spending any cash..
alex45277 There's one of these Hyratrails advertised in the classified ads this morning.I have one of these Easy lifter Hydra Trail's as it has wheels it put no weight on the motorhome and as the wheels are like casters reversing is no bother either, found near new one on FB market place, seen them on Ebay as well although its only slightly dearer than what you are looking at
Easy-Lifter Hydra Trail - Tel: 01509 268400 - £1195.00 Inc VAT
Easy-Lifter Non-Lift system gives you complete freedom on the road - call 01509 268400 todaywww.easylifter.co.uk
