- Jan 2, 2012
- 115
- 39
- Knaus Van Ti 640 MEG
- Had a variety of tents, tipis, motorhomes, caravans and now back to a coach built motorhome!
I have a 23 model Knaus. I changed over to Lithium 280ah earlier this year and switched over the solar and mains battery charger to Victron adding a shunt at the same time to keep an eye on things.
I left the original Schaudt B2B in as it has a lithium profile, however on our first proper test of the new battery setup over 4 days, I was down to 20%, due to staying offgrid, so when travelling I expected it to be putting in its maximum, 25 or so amps, but it was putting in 10 amps at most and was flicking around zero most of the time not putting anything in.
I was monitoring this via the Fogstar app to see what was going in whilst travelling. It’s the OEM wiring it’s not been changed other than the negative via the shunt.
Any thoughts?
If I switched for a Victron unit i wondered if that would help.
Any thoughts?
