The instruction manual for our Globecar Roadscout Elegance says "For long periods of inactivity (4 weeks or more), either disconnect the living area battery from the 12 V power supply or recharge it regularly." Since our van is parked on the public road, we have to run a cable from the house and across the pavement, which makes it hard to charge the living area battery, especially when the daylight hours are short.
However, the Schaudt Elektroblock EBL 119 manual says
...which suggests that you have to charge the living area battery fully before you turn off the EBL and so we have to charge the battery in any case, rather than just switching off the EBL to conserve the battery charge.
That all seems a bit odd to me. Do you think that there would be a problem if we switched off the EBL, even if we haven't fully recharged the living battery first? (We have two 95Ah AGM leisure batteries)
ATTENTION!
Total discharge.
Damage to the leisure area battery:
Fully charge the living area battery before and after closing down the system. (Connect vehicle to the mains with an 80Ah battery at least 12 hours and with a 160Ah battery at least 24 hours).
