S Class Headlight replacement help
tanex
New Zealand
Hymer S520
newbie
Spent a good deal of the day replacing the plastic ball joint sockets on my headlights. What a job!!!
Anyways.. Noticed inner highlight is corroding so need to buy a replacement. Any tips on a source?
Thnk you. My Jymer is a 96 so will ask seller . TEMPTED to convert to projector headlights. 120mm Hella Projectors # HL68131 (High Beam) & HL 68132 Low look like they could be made to fit. Will do some measuring.
have a couple of these on their way. If they are good enough for buses down here they ought to be okay.
Drop this into Google
DOT Approval 120MM Led headlight for truck, bus and motor coaches high beam and low beam headlight
Try this bloke on the bay (Boltonbits).
HYMER MAIN BEAM 120mm Headlamp/headlight 1998 to 2003 B544/574/584/S520/630/e690
eBay item number:
361405358192
I think I have a problem with my ball joint, could I ask where you got them from.
Got mine from an early VW Golf . Do you mean the plastic insert or the metal ball?
Not had a close look yet but I think its the plastic insert.
Well installed new inner light. Bit of a fiddle. So glad new headkight came with all those adjustmant parts and plastic ball joints as the original bits were brittle. Still waiting for 120mm LED units. Now to install a Plug socket for the Inverter.
