RWG stopped working in RUT955
Newcastle upon TOON
Rapido
since 2019
Hi.
Looking for advice.
Ordered my rwg SIM and used it for a couple of calls in UK before departure ferry for 90 days round EU
Installed SIM in rut955 router in Netherlands and it worked fine for a couple of days.
Since then, shows full signal strength but "unable to connect to internet"
I tried the rwg SIM in an old phone (now in France) and get over 100mbps so the SIM data is working, it's just stopped in the rut955
Any suggestions very welcome.
I would check the internet settings on the RUT to see if they have been removed somehow as not connecting to the internet means either they know its in a router and are restricting it (possible but unlikely) or the internet settings have been removed somehow. I am assuming the RUT is still working and has not broken somehow, only way to know this is to put another sim in it to test it (again unlikely but worth checking)
Haven't got access to my 955 at the moment but there's the obvious Allow Roaming and I think there's another to allow it to auto select the provider.
I find if I leave the router on when on the ferry it can't connect when it emerges from the car deck in France or Spain. It connects quite happily after a reboot.
There are 2 APN’s I have found that work.
ion.otm
And
Everwhere
No password for either, you will need to turn off auto apn selection as well.
When I was last in France it did this weird thing where it wouldn’t work for ages on startup then just connected and worked.
On my RUTX50, I've had to manually set the APN for Smarty. I had to use authentication, but leave the username and password blank. The no authentication option didn't work.
For EE, auto works fine.
