Since I bought my A class motorhome (Bavaria I 700) in August, there is a trickle of rusty water that runs off the bottom of the windscreen on the passenger side. I clean it off regularly but I'm wondering if it needs proper investigation. It runs our from the bottom of a panel up the side of the windscreen, but there is no sign of it at the top, so I'm assuming there is some bit of metal behind this panel that is causing it. What I'm unsure of is, whether this panel is purely cosmetic, to hide where the screen is bonded/glued onto the pillar, in which case I could probably carefully remove it, or does it have some structural purpose, which may require professional attention.
Any advice would be appreciated
