By "route to Morocco" do you mean which port to use? Tanger-Med is your best bet, just turn left when you leave the port. Ceuta little difference distance-wise although ferry may be a little cheaper but as Ceuta is actually Spanish you have to "enter" Morocco after you've landed and it can be a bit chaotic.
If you mean a route when in Morocco, just use your map or satnav (you might need a Morocco add-on for it), roads are generally all good.
Watch/post on the Morocco 23 thread for up-to-date info. Checkout my article in Resources, although you need to be a full member to access it - defo worth the cost for all the help and info available.
