RM 7001L wiring problem
Département 87
Profile
Since about year 2000
Hi again,
I had some help around the start of this year with an apparent wiring fault, which I eventually traced to burned out connection within Block 1 of the EBL. With all the pulling and moving within the fridge enclosure one wire has dropped out of the terminal block mounted behind the fridge. I believe it could be a connection to the terminal marked with a key symbol on the Dometic drawing. Where am I likely to find the other end going to? I cannot go grovelling under my vehicle at the moment because of knee damage, otherwise I would make an effort to track it as far as possible. In my vehicle, the wire is coloured GREY, or it looks like it in the light I have here today. It doesn't help tracing things when, in two instances, there is a change of wire colour between the terminal block on the top of the fridge and the block at the rear.
Thanks,
John
