Ring 900 compressor power rating
Cumberland.
Hobby Vantana
Since 2013
I will shortly be carrying out a lithium upgrade and while everything is in bits I want to fit an Anderson connector for a Ring 900 ( a future purchase).
Please can anyone tell me the power rating for the Ring 900, either in watts or amps@12v. I can then get the correct size cable for the connector. Or better still the correct size cable.
Does this help?
Product dimensions (mm): HxWxD186 x 337 x 235
Weight (kg) 3.45
Voltage 12V DC
Wattage 280W
AmpsOutput 23A
Air Line Length (m)7
Max Amperage (A)23
Max Pressure Reading (PSI)100
Power Cable Length (m)2.4
Does this help?
Weight (kg) 3.45
Voltage 12V DC
Wattage 280W
AmpsOutput 23A
Max Amperage (A)23
Perfect thank you..
