Ring 900 compressor air line couplings
gerry mcg
Glasgow, Scotland
Globecar 600L Revn
since 2016
Can anyone shed any light on what the air line couplings are on the Ring 900 12v compressor?
They don’t appear to be the standard 1/4" BSP to Euro Coupler… (I’m looking to connect a different tyre inflator gun to it so i can do both presta and schrader valves), but the air line inflator i use on my home compressor doesn’t fit and the couplings on the Ring hose don’t fit my main compressor.
The ¼” BSP connector is blue, the Ring Connector is Yellow.
The most straightforward answer is to remove the Ring Male connector and get a female 1/4" BSP to Euro Coupler, but an alternative would be finding a connector that had a female Ring connector to female ¼” BSP quick connector
Any ideas?
same question on another forum with a 'possible' solution ..
Thanks scotjimland
Interesting, but not really an answer. I think I will probably have to cut off the connectors and swap them to standard bsp fittings
I could be wrong (as usual) Gerry and can't check our Ring 900 as not at home but does the female socket you plug the end of the yellow hose into not detach from the compressor body?
I think it does have a "nutted" body so possibly fitted by a spanner?
Could you then get a BSP female with the same thread as goes into the body to accept your blue hose?
Any ideas?View attachment 899304
Send your photo to these people and they'll be able to sort out what you want I should think.....
Thanks - that is a great link - it looks Like the blue hose has a Euro connector , profile (that makes sense given the spec of the blue hose i have
I just need to work out the ID of the yellow ring hose and i can buy a coupler with the right diameter barbed end
