The question: Does anyone know where to find what I'm looking for? Seen it every now and then in discussions etc, but can't find it when I need it.
Background: The temp around the sensor is about 3 degrees less than set on the panel, and that's too much for my likings so I'd like to fix that. The panel has that OFFSET -function, I know, but it allows only negative values (which make the situation even worse) so I was going to add a resistor to the system, just need the curve to count a proper resistor value.
