Resealing roof vents
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
I’ve had a search and can’t find which sealant is recommended for sealing the roof vents.
Sikaflex EBD
Puraflex 40
CT1
I’m not fixing things down just cleaning everything and putting a bead around everything.
TheBig1
The problem with using sika or puraflex is they are more of a permanent seal. Rooflights are installed on non setting mastic tape, because of expansion and contraction in the weather and resists moving during vibration. If you are simply sealing the edges, stick with mastic
Two on Tour
Elddis Autoquest 175
Since 2010
When I
Sikaflex EBD
Puraflex 40
CT1
When I changed two of our roof vents over to Thule Omnivent fan units I bedded the new roof vents down on SikaLastomer 710 which is a non-setting butyl sealant.
Silver-Fox
Silver-Fox
Cheltenham Spa
Rapido
im a not so newbie
Thanks for the replies.
I’ll see what I can get hold of 👍
