Is it possible to replace the rather grim looking rear skylight on our recently bought CI Carioca 694, a 2008 model. It’s got yellow fins and winds open by a handle and has no blackout blind. I assume they may be a standard size. Thanks in advance
My original skylight rotary lifting mechanism failed. I replaced the skylight with THIS 400 x 400 version. The lifting method is simple and effective. I removed the old one very much like Guigsy described above - and I'm not skinny!Is it possible to replace the rather grim looking rear skylight on our recently bought CI Carioca 694, a 2008 model. It’s got yellow fins and winds open by a handle and has no blackout blind. I assume they may be a standard size. Thanks in advance
Absolutely any non setting mastic does. I personally use ob1One of the hardest things it's getting a consensus on what to use to reseal.![]()
