Hi there I’m thinking replacing my CBE charger with a victron charger Has anyone attempted this and if so what did you do with the ‘net wire’ that goes to the cbe board
sorry to revive oldish thread but coming across this I thought as the CBE output is 16/22 A the 2amp wire must be protected from over current some way in the CBE unit. Could it not be duplicated for new set upI just left it off all that happens is the mains connection on the cbe panel doesn’t light up. I didn’t want to risk wiring it into the plus terminal of the charger as there is potentially high amps flowing through it and judging by the size of the wire it would only take 2amps
Thanks for sharing your experience,Im considering similar change myself. With the ability to "read" the Victron activity it probably doesnt matter about the Control display. CBE have similar wiring on the Solar, I was thinking of changing that alsoI’ve had the victron charger in place for 9 months now and have had no adverse effect by leaving the wire disconnected, as you can see no one came back with a solution
LiFePO4 batteries are not easily damaged. The CBE charger on its lead acid setting has a relatively short absorption phase (unlike the Gel setting) and soon drops back to its maintenance charge. I find it slightly undercharges my LiFePO4 which usually settles around 90%, slightly better than100% for the battery and I don’t need it at 100% when on EHU. My preference is to spend my money on a good B2B so that it is 100% when not on EHU.CBE has no Lithium setting. Battery suppliers say existing setups inc CBE are adequate but much more knowledgeable members eg LennyHB have doubts about this especially the Float charge pattern on AGM or Gel settings. L1Fe PO batteries are a bit dear to damage.
Slight Undercharge sounds better than staying at full under no load, i believe) for Li so may save some outlay.LiFePO4 batteries are not easily damaged. The CBE charger on its lead acid setting has a relatively short absorption phase (unlike the Gel setting) and soon drops back to its maintenance charge. I find it slightly undercharges my LiFePO4 which usually settles around 90%, slightly better than100% for the battery and I don’t need it at 100% when on EHU. My preference is to spend my money on a good B2B so that it is 100% when not on EHU.
i presume you have/had a split charge system associated with the CBE system. Did you have to disable it when B2B fitted. If so was it easy? (Ive read a thread about the Sargeant split charge system being problematic to remove) If not does the higher charged voltage of Li trickling back to the starter battery cause it damage.LiFePO4 batteries are not easily damaged. The CBE charger on its lead acid setting has a relatively short absorption phase (unlike the Gel setting) and soon drops back to its maintenance charge. I find it slightly undercharges my LiFePO4 which usually settles around 90%, slightly better than100% for the battery and I don’t need it at 100% when on EHU. My preference is to spend my money on a good B2B so that it is 100% when not on EHU.
Thanks for this so it’s sounds straightforward enough.Can I ask which Victron unit you picked to replace your CBE one ?cheersDitto to the above, changing it was easy just taking the mains wire off of the cbe charger and put them into the victron as I’ve stated before I didn’t fit the wire which goes to the cbe control panel as there is no place to connect it on the victron
Last question if you don’t mind . If you didn’t replace the 2 amp wire would that also disable the vans under voltage alarm?IP22 15amp primary only 15 as I’ve got a B2b, 220w solar and a 110amph lithium so if I’m hooked up for the night 15x8hr will recharge if the lithium was well and truly discharged and as I’ve got the B2b it never is
It didn’t on mineLast question if you don’t mind . If you didn’t replace the 2 amp wire would that also disable the vans under voltage alarm?
