Please note all of our G4 LED lamps are voltage regulated, include voltage suppressors and are not polarity sensitive - i.e. the LED will light up whichever way the positive and negative power is applied so no rewiring is required.
I fitted one of those in our bathroom. A standard LED just didn't cut it. Nice and bright now.As Jim says Aten is the place.
I fitted these and got cool white , as I prefer that to the yellowish warm white
Always thought of Aten as being competitively priced rather than expensive, excellent bulbs and quality replacement fittings, Their USB spotlight range is better & a bit cheaper than Dimatec who supply the coachbuildersG4
I use Aten LEDs .. best on the market..
I have been using these since 2015 .. in three different vans, and never had one fail
they are voltage regulated from 10-30V,.. not the cheapest, but buy cheap buy twice ..
Tip
If buying elsewhere cheaper, check if they are voltage regulated, if not they may fail when subjected to higher voltages when charging
G4 LED - Aten Lighting
www.atenlighting.co.uk
Changed all our lamps to LED from Aten.G4
Tip
