That’s the one, made a big difference.If you want to stay legal, Osram Night Breakers.
I fitted LED's to the last van it passed 3 MOT's with them.
Thought night breakers were 100watt so not legal.If you want to stay legal, Osram Night Breakers.
They are brighter by running at a higher temperature. This means the fillament is easily damaged and so tend to have a short life.Thought night breakers were 100watt so not legal.
Just seen they are just 55watts...dont understand how they can be more than twice as bright.
I think we've moved on since the days of candles 68c
Just how do they burn at a higher temperature.They are brighter by running at a higher temperature. This means the fillament is easily damaged and so tend to have a short life.
Tungsten metal used for the filament has a melting point of 3422°C, the highest melting point of any metal. When it is very hot, but before it melts, it slowly evaporates. In a non-halogen bulb, the tungsten metal deposits on the inside of the glass envelope. You may have noticed the glass of old sidelight bulbs looking shiny and metallic.Just how do they burn at a higher temperature.
They are a 55watts filament and use halogen gas.
The only difference I can think is the filament material
