I want. To replace the Motorhome wifi aerial with a poytning 5g/wifi and gps Antenna. Do they come off easily? I th8nk they have some kind of 3m glue patch on them?
Use some thin stainless lock wire as a cheese cutter to cut through the rubber substrate then scrape the glue off the roof very carefully with something kind!
You can use a rubber wheel on a drill, but a thumbnail is easier to control
And safely remove all the old body striping in minutes. Unlike chemicals and solvents commonly used for this job, the soft wheel is gentle to the finish. -For use with electric drill. -Designed for high-speed removal of vinyl, decals, graphics, double sided molding tape, striping and trim.
www.ebay.co.uk
