Renogy 50A DC to DC on board battery charger with MPPT , on Transit with twin batteries ?
Dolgellau, UK
C20XEL400PE8W
Hi folks, I've been following a thread about this but I'm still not sure where I should be connecting this charger for the best results , maybe I'm being a bit thick !!
The bulhead is removed and I will be installing a leisure battery (AGM) seperately in the rear.
Could someone explain in laymans terms as I'm struggling to work it out.
Thanks in advance.
Pete.
The B2B connects between the starter battery (the input) and the leisure battery (output from B2B).
The MPPT (Solar) just connects to the leisure.
If its a long cable run best to have the B2B near the leisure battery.
With the Renogy it reduces the B2B charge rate by 50% if it detects any solar input so best to fit a switch inline with the solar input.
I would reconsider the fitting an AGM they are pretty useless as a leisure battery.
Brilliant Lenny, thankyou for that.
Theres a minimal cable run and I will have to see if I can run to a lithium battery , I already have a 120ah lead acid.
Regards, Pete.
