Removing driver side footwell on Bailey Adamo 2023
Bailey Adamo 75-4i
How do you remove the driver side footwell on a 2023 bailey adamo 75-41 please? Need to access air compressor for rear air suspension. Thanks. Barrie
Maybe ask your supplying dealer ?
Base vehicle would be useful to know for anyone interested in answering
It's unlikely that it's a factory fit air suspension.
There's also not much space in the driver's footwell. There's space under the seat though. There's also a bit of cavity under the floor panels on the passenger side.
Yes and I will but I have only just linked with my nearest dealer. I did not buy the van from him so a little hesitant. That's why I am here on the forum with the question Regards Barrie
Sorry but Base vehicle is Ford 'Skeletal' chassis. Van Amado 75-4i. Barrie
We have an Adamo and our dealer knows very little about the Ford base. They are more used to a Fiat and Peugeot.
Try a Ford Commercial dealer. Bristol Street have one near us. It might cost you for advice but you will probably have to go there for servicing anyway.
You would be better served asking on the Ford Transit forums. Lots of info there.
Hi, and 'Ta muchly' I think you are correct, a Ford dealer will have the answer. Barrie
Hi and thanks for the comments. Barrie
Unless the previous owner has had air suspension fitted, it doesn’t come as standard on the Adamo
Hi should have made it clear - I had the Air suspension fitted but during this process water was found in the footwell so I want to now check it occasionally to see if it's still dry. The company fitting are some way away from me so this forum seems ma. likely place to get the info simply. Regards Barrie
