Removing battery from floor well
coachbuilt
since 1974
I am wanting to change the battery (Vehicle ) and think that if i could remove the large bulky unit that sits over the battery site with the cup holders etc on it would be a straight lift job . Also what battery do members recommend for a 2016 Ducato Maxi chassis 2-3 130 . existing one, cant see a name is 353X 175X190 mm. Any suggestions welcomed.
You should get one with 900 / 950 cold cranking - a lot of battery places try to tell you 750 cc (fitted from new) is ok but Fiat said you need 900 cc - amps not so much a problem but cc is 👍
If you know someone with a Halfords Trade Card you can get a very big discount on batteries.
hi,
anyone know if disconnecting battery activates tracker ,Phantom VTS and what to do to avoid
