Removal of high level brake light ducato van HOW? (1 Viewer)
Sep 10, 2012
2,164
4,083
worcester
Sunliving van
Looks simple enough - 2 big screws holding it in?
Screws out gently ease the fitting.
Expected it to fall out but no there must be something holding it.
Before brute force what the hell is holding in place?
TIA
Aug 1, 2021
1,042
5,920
Pembrokeshire, UK
Auto-T Expedition 66
When I removed ours to fit a reversing camera I experienced exactly the same as you. The plastic lens seems to bond itself to the metal surround (it's probably caked on dirt)!
Gentle prying with a couple plastic pry tools (one at end) loosened it and it popped out.
berni109
Sep 10, 2012
2,164
4,083
worcester
Sunliving van
Thanks Barti Ddu .
Like you say it was not easy to pry the lens off the bodywork.
But there seems to be something else holding the complete unit in place. It's loose but won't pull out easily.
Aug 1, 2021
1,042
5,920
Pembrokeshire, UK
Thanks Barti Ddu .
It's over a year since I removed it to fit a reversing camera, but don't recall any other particular issues with removing the original unit. There's a cable obviously, but think that there was plenty of play to extract the assembly.
Maybe you need to be a bit braver with it, giving it some force. Good luck.
Gellyneck
9,818
19,952
Scotland
More than toes wet now!
Aug 1, 2021
1,042
5,920
Pembrokeshire, UK
This YouTube video shows how easily it should come off.
I wonder if the square plastic mouldings on the back of the brake light unit have impaled themselves too forcefully on the square brass threaded mounts on the van? (See around 2 minute 40 seconds in the video). Be brave. Give it some welly! šŸ˜„
berni109
Sep 10, 2012
2,164
4,083
worcester
Sunliving van
That bit of bent metal in the photo was a very tight fit at both ends. Acting a bit like spring retainers.
Brute force (and bravery) was all that was required.
I checked before the brute force and a replacement was Ā£20 on the bay.
Thanks for the encouragement .
