Remis blind frame not secure
County Durham, UK
Hymer Free 600
Only a year
The rear RH window blind is not secure at lower LH corner as shown in picture.
This is on a one month old Hymer so will be contacting service department but wondering if it is an easy fix I could do as dealer is 180 miles away from home.
Advice appreciated.
Mine is only fixed by steel clips pushed into the frame. You should be able to push it back up into the frame.
Or pull it down entirely and off and refit the clip's
Had another look this morning with rear doors open and it is actually due to a screw coming out.
I heard screw rattle inside so not missing, just home the hole in plastic cover is not too big now.
At least I can fix easy enough without need to contact dealers.
Thanks for advice
Oh, that is not window/blind in discussion but the other rear door and it had a cover missing.
How? They seem to be very tight fit so maybe I missed it on collection of van.
To close this out.
I used a larger screw to secure the blind on LH rear door.
Contacted dealer and (surprisingly) that are going to post out a replacement corner piece for RH blind for free.
