Reliability of IVECO based motorhomes?
Carthago A class
Considering an IVECO based Motorhome but the 2022 one I was looking at has just gone off to have its airbags replaced and has already required a wheel bearing. Trustpilot review of IVECO is pretty damming.
I’d be grateful for anybody’s experience of IVECO.
Thank you in anticipation
Ours has not been any worse than any other brand, but keep off any one with Lane correction and other modern assist gimmicks as they are crap, best around 2017 before adblue was fitted.
But this is only my opinion 🙂
Ours seems fine, but only 9000miles so far. Also 2022. We have done a couple of things to improve the ride, setting the front torsion bars for the correct weight, and beefing up the dampers to take account of the always fully laden factor, and ignored the Carthago Front semi air pressure advice, and found around 4bar gives the best ride.
We also ignored the Carthago tyre pressures, and wen with the pressures given for oour tyres and the vans actual weight as set out in the Continental Tyres databook downloaded from Continentals site - they will also advise these settings if you call them with the vans axle weights.
Stay away from that one or stay away from IVECO?
We run a big fleet of sprinters at work, very reliable , and they do not have an easy life, I only drive it my self on occasion as I drive HGV vehicles ( no HGV driver ever said he wants a Iveco truck) I find vans not very comfy at all regardless of brand, around 21/22, sprinters were very difficult to get and I know of a outfit who changed there little fleet of 6 sprinters for 6 iveco’s , they amount of trouble they had with it was unreal, they changed back to sprinters pdq 👍
I've got 1 Iveco on the fleet and I won't have another 1 the van itself is okish but it has had a gearbox fail which was replaced under warranty but it nearly a month to diagnose the fault its only done 160k miles and the backup is absolutely rubbish mine is also 2022
