Regulator problem (1 Viewer)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Not as far as I'm aware, why would you? I assume you refer to a gas regulator, presumably a Truma/Gok unit that has failed?
D.
leggings
Apr 10, 2018
150
144
Gt Manchester
Hobby T500
10 yrs
Yes you are right Dave heating keeps switching off just have to keep switching it back on again. Have had regulator problem before on Truma regulator and suspect that this is the cause now. Just bought a Euronozzle for refill and the company advertise ic12 for injectors cleaning thought this may work on regulator.
43,765
52,828
Never used to be a problem then something changed a few years ago.
Instead of fixing the regulator problem they developed a filter, at a price of course, which apparently doesn't always work either.
. There's quite a few threads on here about failed/gummed up regulators.
Its supposed to help if the reg is mounted as high above the bottle as possible.
leggings
Apr 10, 2018
150
144
Gt Manchester
Hobby T500
10 yrs
Thought it was something to do with oil in LPG I will have a look for other threads.
Thanks for your advice.
Pugsy
582
1,490
D&G
Van conversion
Since 2012
I changed a Truma regulator with the same problem on a van before trading it in and then the Truma reg went 2 days after getting the new van.
So I don't use them now.i currently use a cavagna reg.
Cheers Chris.:cheers:
leggings
Apr 10, 2018
150
144
Gt Manchester
Hobby T500
10 yrs
There was a problem with the regulator shortly after purchasing the van and had to get it replaced under warranty. Now the heater switches off after it has been on full heat. Thought i’d Try cleaning regulator with injector cleaner. Sounds like Truma need to up their game.
Thanks for your information.
43,765
52,828
Yes, I believe it is but was never a problem on the old truma regs. As I said, instead of fixing the reg problem they masked it with a filter.
Other regs don't appear affected.
JockandRita
11,875
158,610
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I'm still on one of these, fitted almost 20 x years ago...........
..............and although it is still going strong, I do have a new regulator on standby, should this one fail. ;) There are no filters in the system that I am aware of, and it is solid pipe all the way from the bulk tank, so no worries about the leaching of oils or residue from rubber hoses.
Cheers,
Jock. :)
P.S. I should have said, that I am unable to source the exact replacement new, so have chosen one of these.
43,765
52,828
Cheers,
Jock. :)
Have you also got the union adaptor for the right hand connection Jock. :whistle:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
That sounds more like a problem with the heater than a failing regulator. I certainly wouldn't try using any kind of cleaning fluid in a gas regulator, you can't be certain you got it all out and you don't know what it might do it if gets to the burner of an appliance. The oil is present in all lpg, the problem with the regulators is the oil, if it gets into the reg, contaminated the diaphragm causing it to swell. Cleaning the oil out will not fix the swollen diaphragm.
D.
Aug 19, 2014
1,921
5,889
Cliftonville
A Class Burstner
Since 2014
The Truma problem seems to really affect those with the crash sensor.
Truma recommend fitting a filter. Truma blame the gas suppliers saying there is too much oil/contaminants.
If a known problem ,why don’t Truma supply their regulators with a filter as standard?
JockandRita
11,875
158,610
Lincs/Cambs border
N+B Flair 8000i
Sods law it'll fail when you can get one. :mad:
Agreed John, but a visit with the MH and the regulator, to a respected Auto LPG Converter and Installer near us, proved to be fruitless. :(
@leggings. Sorry, I didn't mean to hijack your thread. :oops:
Good luck finding the problem. (y)
Jock. :)
Aug 6, 2013
12,057
16,791
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you have ever tried to use a blowtorch off a close-to-empty bottle you will understand the so-called oil or low-ends problem. Although gas is drawn off the top of the bottle (which reasonable leads one to believe the oily stuff stays at the bottom) this is not entirely the case. At least some of the oily stuff will vapourise as the pressure in the bottle drops. It burns yellow with a foul-smelling flame and if the flame is played over an object it deposits some sticky liquid. It may be that regulators are damaged by regularly running bottles or tanks to empty.
andy63
4,672
15,019
south shields
None
since 1990
Curiosity got the better of me when i was given a failed regulator..
I opened it up and best i could tell is the valve seat on the first stage of the regulator was the culprit... i think it had enlarged causing first a restriction then a total blockage to flow of gas... its not the oil or residue that blocks the jets...
The valve movement is tiny and it wont take a lot of swelling to cause problems..
Couple pictures showing the two chambers of a regulator...
The second one shows the first stage chamber and valve which had blocked.. you can see the liquid deposots lying in the bottom of the chamber.....
leggings
Apr 10, 2018
150
144
Gt Manchester
Hobby T500
10 yrs
D.
Thanks for that Dave think,it is good advice.
