can I put the question another way ... if we fit 2x11kg for ‘belts and braces’ but actually only ever used the first one ... is that a problem. Would the second one seize up? I presume there’s no BBE date on using gas ?.
57 near me so 12 litres (around 6 kg apparently = £6.84 and last time I exchanged a calor lite it was £28, so on that alone, the saving was over £21 on one cylinder.When you think about it a 6 kg Calor is around 24 quid that’s 2quid a litre, an 11 kg bottle holds 22litres, filling 22 litres at 65 p a litre is really a no brainer. IMHO
Well we did 6 weeks in France, Germany, Switzerland and Italy and topped up when convenient as one thing is for sure, it doesnt go down that much in price and although we get at 57 a litre, you can get cheaper or a lot more expensive.Unless you are out on the road for a length of time you will not use your 11kg.to empty.
Consider just one 11kg refillable and a bluetooth cylinder monitor. That way you always have an accurate measure of how much you've used and how much leftOk thanks guys ... now we are BOTH convinced that refillable is the way to go ??.
We’re erring towards 2 x 11kg. So a couple more questions ...
- what would the advantage be of 1x11kg plus a spare 6kg Calor over 2x11kg refillable (more interested in functionality over cost tbh)
- from the responses I gather Alugas, Gasit/Gasit Plus and Gaslow are the main options?
thanks for helping our thinking ...
We never let one tank run out completely. When one starts getting low we just switch to the other and start looking for a convenient place to refill. Otherwise you will find that the tanke will run out at 1am and your fridge will start beeping at 3am and you have to go out in your pyjamas to change bottles, and it will always be raining!can I put the question another way ... if we fit 2x11kg for ‘belts and braces’ but actually only ever used the first one ... is that a problem. Would the second one seize up? I presume there’s no BBE date on using gas ?.
We just use one then when we refill we use the other one, then after the next refill, use the first one again, that way both bottles get a 'work-out'!can I put the question another way ... if we fit 2x11kg for ‘belts and braces’ but actually only ever used the first one ... is that a problem. Would the second one seize up? I presume there’s no BBE date on using gas ?.
Please ensure that your canoe can't trap any escaping gas in it's 'folds' or bag and thus prevent it escaping through the bottom drop out vents. When I put anything in my gas locker in a bag I use 'net' ones so that they can't fill with gas and anything that could possibly hold escaping gas is placed high up in a door basket (hose pipe). If you need to put your canoe in there put it in a completely air-tight bag so no gas can get into it at all and obviously don't block the vents.We mamage four weeks in south of france on one 11 kg alugas without having to fill up removed the second bottle for weight and to fit my blow up canoe in its place
Is it airtight though? If not gas 'could' get in the bag and get trapped in it and/or the folds of the canoe - I have had a few inflatable canoes and they all create some 'air pockets' when packed, no matter how well you do it. Don't want you to go boom!Thanks for warning re gas but im ok the canoe fits in a bag very similar size to gas bottle and gets strapped in as the spare bottle used to and then doesnt foul the floor vents so all ok thankyou though
Basically how we plan to use ours.We have one refillable and space for another but have never had an issue with just the one refillable one as once the gauge gets to the end of the green we just top it up as soon as we see somewhere.
If we were desperate we could get a calor or similar and feed through the BBQ point but the big advantage for us is no lifting in and out of heavy bottles of gas.
I should also add that generally we fill on the way home from a trip so have a full bottle to start off with
Sensible. I would recommend getting a bluetooth level sensor though. The one on the top of the tank is really useless unless the tank is nearly empty. The bluetooth sensor is more than accurate enough to allow a good prediction on how many day left before empty as you can check usage day by day.Basically how we plan to use ours.
Max we would be away is a week or two so a single 11kg should do us. And just top up if needed but unlikely. Then fill when we get home.
Also frees up some locker space so we can put the Cadac in there
If going away for longer or more remote, say NC500 then I may throw the spare calor in as we already have it.
If we retired and went away for longer periods then would look at a second refillable.
You can also connect the patio heaters to it, as well!I also have a external barbecue point which I can connect a external cylinder if need be
( ideal for north of scotland )
Check out Safefill.
Watching this thread with interest. I’m considering getting a Safefill bottle myself for future trips to France (mainly) and of course the UK.Can you refill them in Europe?
