Recurrent Injector Issues with 2019 Transit Vans (3 Viewers)
Feb 17, 2012
825
7,291
merseyside
Murvi Pimento
Where can I find such an item, or was it simply made by a contributor to the forum? Thanks.
Rob Drew on the Adamo owners FB group sells them. I will see if I have his messenger contact details still and PM you.
Feb 17, 2012
825
7,291
merseyside
Murvi Pimento
Jonno1103
1,422
1,602
Harrogate
F Line F70
Update, injector 1 replaced by Ford under warranty, thankfully. Asked for an explanation, was told that the problem was due to the long time that the base vehicles spend sitting around between being manufactured and then converted. I then said that this could be understandable if this was the first time the injector had been replaced but this was the second time. Was then told that I need to be driving more to stop this from happening as the injector tips corrode if not used enough. Haven't managed to find any mechanic who supports this statement. Also was told that fuel additives can cause this problem. BS in my opinion.
The issue is caused by an engine air valve which in motorhomes used periodically causes condensation build up. There is a Ford software patch to permanently close the valve without any problems. If you don't use your moho all the time best practice is to drive it once a month for a minimum of 15 minutes at 2000 rpm. The cures it.
The other issue is with the BCM. Condensation irrigates down inside the windscreen through the dashboard and damages it. Ford have a moho specific cowl to deflect it or use of an external thermal screen cover sorts it too. If you have hab' air con use this as it'll dehumidify the whole van interior. Internal Remis blinds are simply for privacy, they offer zero thermal protection.
Jonno1103
1,422
1,602
Harrogate
F Line F70
Thank you.
Doesn't work. I know hire companies that have spent a fortune fitting this only to have their injectors fail on multiple vans. Water irrigating through the rain scuttle is caused by a poor fitting screen surround trim... it doesn't get anywhere near injectors on an Ecoblue Panther engine, they're buried deep centrally in the engine block. It was a big issue on the older Duratec engine where the injectors are housed exposed at the rear of the block. It was also an issue on PSA cars & vans too when they shared the engine until 2017... The Citroen Grand Picasso & Pug Partner were renowned for it.
If your moho is still under the Ford 3 year warranty they will replace and rectify the issue FOC.
All of the modern images you see on facebook & youtube of bright orange 'rusty' injectors is a load of rubbish... It's the colour of heat paste.
May 29, 2013
2,707
21,318
Tyneside
Chausson best of Flash 10
Several years now
I have a mk 7 2.2l fwd engine, does the air valve you refer to above exist in my engine, if so whereabouts is it located ?
Thanks.
Jonno1103
1,422
1,602
Harrogate
F Line F70
Thanks.
Different engine, you have the Duratorq, the Puma, which was also used in the Peugeot Boxer. This engine is renowned for injector issues due to their placement high up under the rain scuttle. The Citroen & Pug SUV's, people carriers and the smaller vans also suffer.
It was used in the MK8 until very late 2016. 2016/'17 model year vans tend to be the first with the Ecoblue, the Panther. The injectors are centrally mounted deep down.
Aug 18, 2014
24,841
145,203
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Thanks.
No
Easy fix as it is caused by the wiper motor fixing holes for either left or right hand drive being unused & allowing the water that gets under the plastic trim of the lower windscreen to drip down & fill up around the injectors.on a left hand drive it is usually 1& 2. I just sealed the spare holes off & no more water except exiting wher it should on either side.
Jonno1103
1,422
1,602
Harrogate
F Line F70
No
I agree gus, an easy fix. Problem is not many bother.
Dave1966
Apr 23, 2015
29
31
Ford Coach built
3 years and counting
Well the latest is that, following #1 injector getting replaced in may, we have just managed to get away for a few days. The van has been run since, but just out for a habitation check (130 miles round trip) and a service at my local workshop. On the way back today, just as we turned onto the main A30, juddering again, limp mode and stranded on the side of the road. Breakdown truck called, diagnosed #3 injector this time. Recovered to the main dealer who changed #1 back in May, told me that initially a £168.00 diagnostic fee is due before they can get the van into the workshop, maybe not for another 3 weeks but they will try. At my wits end now, have emailed Lisa Brankin at Ford as per meanders suggestion above. Begining to wonder whether Ford have a batch of old injectors that they are using up.
Feb 19, 2018
5,836
92,078
EAST ANGLIA
Murvi Morello
Since 1975
Sorry I haven't read the full thread but a few years ago, a friend of mine had similar problems and, after replacing 3 different injectors on 3 different occasions, he was lucky to find a man who found the problem in the wiring harness to the injectors (it had been chaffing a known fault apparently) and fixed it.
Sadly cannot ask him as he's no longer with us. 😢
Feb 17, 2012
825
7,291
merseyside
Murvi Pimento
I’m a member of a few FB groups and apparently you need to replace all 4 injectors at the same time. Ford UK are authorising this on vehicles within the warranty period.
Feb 17, 2012
825
7,291
merseyside
Murvi Pimento
Apparently the tray stops the external corrosion though so makes the injectors easier to remove when they fail. After having to pay to get my injector drilled out and the other 3 changed as they showed signs of external corrosion I really don’t trust that water can’t get to the injectors and would rather spend out on a tray than a specialist to drill the injectors out.
Dave1966
Apr 23, 2015
29
31
Ford Coach built
All four were replaced under warranty in 2021, 2 of those have since failed!
Feb 17, 2012
825
7,291
merseyside
Murvi Pimento
Does this Ford software patch to close the valve get done automatically if the van goes into a Ford garage for its service, or is it something you can request is done? Can an independent garage do it or does it need to be a Ford garage?
Jul 13, 2023
722
2,861
All over Europe now
Adria 680ST Gold
Ford are talking complete nonsense ,,,they have injector problems on regularly used high mileage vans and cars and petrol models it FORD that is at fault for rubbish quality ,, bad design , same as the wet belt engine scandal.....FORD = FRAUD
