Recommendations for leisure battery
Many of us use Tayna and I've found them competitve and very helpful when I had a problem. Assuming your battery has a dedicated space make sure the replacement has the same dimensions and the + and - cables will reach/match the terminals.
If you do not replace the battery with the same type make sure your charger supports the battery type.
