Rear view camera mrror fault
Swift Bolero 2013
Morning
I have a Swift Bolero and for some reason the mirror for the rear view cameras has suddenly stopped working. It did this once before but came back on again.
I have had it in pieces to see if a connector had come off but the wires are soldered directly onto a pcb. I have nothing that tests down to 12 volts and the feed is on a moulded plug anyway.
Has anybody had a similar problem out there ?
I had the same problem on my Bolero
It was the camera that needed replacing I purchased one from eBay wasn’t very expensive it came with the wrong connection on it for the existing wiring I simply took both of them apart and found I could swap over the connections they had the same connection on the pcb put back together carefully and it’s still working a year later
Thanks very much for that and it sounds like a plan. I'm just going to check over the weekend if there is power to the connector now I have found my multimeter (our MH is not kept at home).
Was it a like for like mirror or just something similar ?
7inch Car Rear View Mirror, LCD Color Screen HD 800 x 480 Car MP5 Monitor Auto Dimming Monitor Rear View Camera With Bracket https://www.amazon.co.uk/dp/B08GMCS3XB/?tag=mhf04-21
I have the twin lens camera i replaced the EM7 module first ( located behind the cab to Motorhome body plastic trim near the floor ) it was not this
