Tim Hamlyn
Hi. I have a low rear opening door to my storage area in the MH. It is only about 10 inches high but is the full width of the vehicle. The MH has a towbar fitted which I want to keep. The problem is long before the rear door is fully open it hits the tow ball. The door is hinged at the bottom. I was thinking of replacing the original hinges with flight case hinges so I can detach the rear door and get full access to the storage area. Has anyone done this and if so can you recommend where I could get hinges. The only ones I can find are too small to support the door. I cant use the type that separate by sliding sideways as there is not room to slide the door sideways.
Tim
Tim
