- Dec 31, 2021
- 589
- 546
- Adria matrix supreme
Hi all I am after thoughts of what may have gone awry. We have rapido 9068, it came with lithium leisure battery as standard, I have replaced the original with 2 matching renogy 100ah wired via fuses and bus bars and fitted a inverter. The van is parked across the front of the house so we leave the control panel on to use the van wi fi in the house, I normally put it on ehu at home but have been having issues with the cab battery holding charge for more than a few days so since last sunday have not had it plugged in and monitoring the cab battery via the tracker app.
On friday the control panel went off so it seems the hab lithiums have gone flat, the test meter on the battery terminals is only showing 0.65v. I put it on ehu overnight, that has 240v where it enters the van and both trip switches are ok.
Is it too cold to charge the leisure or have they shut down due to low voltage?
Any thoughts where I should start checking things out would be appreciated
Tia chris
Tia chris
