Hi does any person know how to remove slide out cuboard can’t see any thing on runners to remove
Can you be a bit more specific as to where the cupboard is?
Think you best put more details up, even your profile is vague 1990 Homer a class could be any number of fittings.Hi it’s the one just inside the door that pulls out for bottles about 2ft x 2ft sink drain on top thanks
It’s on rapido 962 a class 2002 left hand drive I need to take the cupboard out to clean behind it so that means to release the runners tried lifting there seems to be nothing on runners to release
If you can’t get to all the screws then there must be a release. Otherwise they would not have been able to attach them.That’s not possible as you cannot get to back screws tried that there has to be an answer so simply that I can’t see
When you pull drawer right out till it stops, is there anything that pops into that square section on the left of your picture. Or can that black insert on right be removed? That could be a stopper
No nothing I’ve pushed pulled undone screws still will not releaseDoes it have this type of fitting under the drawer? If so you need to press the orange part sideways to release the runner.
Sometimes the screws are accessed via the holes/windows in the runners so you have to mess about with where the runners are together to the back screws. This is better done with the easy to get to screws left in place till the difficult ones are removedThat’s not possible as you cannot get to back screws tried that there has to be an answer so simply that I can’t see
