Rapido 924F Sink trap sealing ring - Help
England
Rapido 924F A Class
Since 2010
We are off to France tomorrow evening and when adding a little water ........ I got a puddle in the cupboard under the sink. I assume that the rubber seal needs replacing.
Can I get an O ring selection from B&Q to fit????
Thanks for you experts out there who can solve my last minute problem!!!
Rob
I can't answer re getting one from B&Q, but it's worth a try I suppose. Take the cap with you for comparison.
If no joy, remove the existing O ring carefully, clean it, then the cap, plus the mating surface of the waste pipe. Next, smear some silicone grease to the recess in the cap, then on the O ring, then on the mating surface of the waste pipe. Assemble it all hand tight, plus a bit, and test for leaks.
Good luck,
Jock. :)
If you can’t get a seal a wipe over with silicone sealer. Let it dry and will be ok till you can properly sort
Thank you
Good luck,
Jock. :)
Thank you Jock, I cleaned it up carefully thenput it back in place. I noticed that it could be tightened on clockwise and anti-clockwise. I tried anticlockwise and tested it. It now seems okay, no leakage. Saved me a trip to B&Q!
Thank you, if I get a further problem I'll try that.
Thank you
Tightening either way, explains the flanges seen on the cap in your image.
I am pleased that you are sorted. 👍
Have a Pelforth Brune for me please when you are in France. ;)
Cheers. 🍺
Jock. :)
Avoid B&Q and go to a plumbers merchants/supplies. Taking it with you.
They’ll have no end of sizes available, and they will be more stores to chose from
