- Oct 12, 2009
- 11,491
- 25,438
- A Class N+B Arto 69GL
- Since 2009
It is known that ideally one should use a flat weighbridge to get accurate individual axle figures.
Some of us do not have access to a flat one, only one with approach and exit ramps.
With a ramped weighbridge if one has an axle just on the plate the other axle is down the ramp and taking some of the weight off the axle being weighed, so inaccuracies creep in.
In order to try to compensate for the inaccuracies I have thought of this method, which may have been suggested before.
THIS METHOD FOR COMMENTS PLEASE
On a flat weighbridge the two axle weights should add up to the GVW.
On a ramped weighbridge they will almost certainly fall short of the GVW.
So for example the GVW is weighed at 3800kg but the total of the axle weights shows 3600kg. Therefore the inaccuracies caused by the ramps equal 200kg.
The 200kg needs to be added to the axle weights to compensate for the inaccuracies, but adding a straight 100kg to each axle weight would not take account of the usually unequal distribution of weight between front and rear axles.
To compensate for this unequal distribution I propose that one calculates the ratio of distribution by front weight /rear weight and apply this ratio to the 200kg and then add each portion to the weighed axle weights.
This formula may not result in an totally accurate figure compared with a flat weighbridge but should give a good approximation.
COMMENTS PLEASE
COMMENTS PLEASE
