Minxy
- Aug 22, 2007
- 34,527
- 73,917
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
If you're after a cheap sim for home or abroad use then there's an offer on with Quidco at present for £15 bonus cashback on top of the normal cashback when buying sims from Lebara, Asda, Giffgaff or Smarty. This is in addition to the normal cashback you get anyway.
There's also a voucher code to bring the cost down for 30 day sims to £1.99 for 3 months but this only works on a couple of them, namely:
The below sounds complicated but it isn't so long as you do as instructed namely: 1. opt in and 2. enter the discount code.
In effect you are getting the sims for nowt for 3 months as their cost is more than covered by the cashback!
Are you ready, steady ... GOOOOOOOOOOOOOOOOOOOO!!!
If you've done it correctly you should get a confirmation on screen that you've opted in like this:
Now you can purchase a sim:
20gb @ £8pm reduced to £1.99 for 3 months if code used (normal cashback is £8 or £6 depending on Quidco membership level)
25gb @ 10pm reduced to £1.99 for 3 months if code used (normal cashback is £7.50 or £10 depending on Quidco membership level)
- Go to Quidco & log in:
- Click back to Quidco homepage
- Look for the offer on the left a little way down the screen (below)
- CLICK ON THE IMAGE to opt in (if you don't you won't get the bonus cashback!)
- Search for Lebara
- Scroll down to the bottom of the screen to see the relevant sim offers- the discount code only works on these:
- 4th from bottom = 20gb @ £8pm (cashback shows as either £6.00 or £8.00)
- 6th from bottom = 25gb @ 10pm (cashback shows as either £7.50 or £10.00)
- Click on Get Cashback on the sim deal you want
- Click Buy (it will show at the full price for the time being)
- Put in your details & continue
- IMPORTANT!!! Complete the sections then add the discount code and the cost should reduce to £1.99 a month, the code is: Lebara10
- Finish the purchase
