Quick question about lead acid to lithium golf cart
Tombola
Merseyside
Rapido 8094DF
Since 2004
We have an old golf cart we used to use for nipping round our works from unit to unit, it has 4 old trojan Lead batteries .
Is it no problem if i change these for 1 large lithium?
£60 each. 16 needed.
Probably want a BMS as well. Not sure what the current draw is but if it is 100A or less then another £60.
Just a suggestion for a starting point to do it cheap. No idea of how it would work or integrate as not enough info.
It would be relatively easy to build a 16-cell (48v) LiFePO4 battery. You could use 100AH, 200AH (or 230AH) or 300AH cells depending on budget and power requirements. I’d go for a JK or JBD BMS.
The reason 16 cells are used is that four 4-cell '12V' can be connected in series to give '48V'. However if you do the calculations, and are adding one cell at a time, then only 15 cells are required to give the equivalent of four 12V lead-acid batteries. Many 48V battery packs such as the Pylontech ones have 15 cells, not 16. Obviously the charging voltage needs to be adjusted a bit.
Although 16 cells will probably give the cart a bit more pep. 😁
Would not the modern golf buggies have lithium batteries and have a tried and tested set up worth following?
Or is that too easy?😄
Not quite, pylontech switched to 16S as the 15S was constantly abused and singled out.
The 16S it has a absorb lower or close to Pb and lower float to. Inverter turn off it’s way to high on a 15S. Some inverters are preset without being able to change that.
The victron gear is good for 66v so you want to keep the voltage as high as possible for good efficiency, the 16S it’s the Goldilocks on lfp. I know a guy running 8S Nissan Leaf modules, 60v on a Studder.
whats to stop me chucking in a 200ah 12v Lithium that I have lying around ? with built in bms
does it have to be 48v or maybe 24v? I have 2 x 100ah too
I was looking here and notice they have 24v cart batteries ?
The vast majority of lithium batteries cannot be placed in series with each other, so your current batteries may not work.
If your lithiums are many cylindrical cells, you could potentially reconfigure for 48v. Probably need a new BMS though.
