Does anyone know how to get stickers (angles mort etc) to stick on the van when it has had ceramic coating done, as I keep losing them.
When you say van, is is a PVC? You can buy Magnetic AM Stickers now. If you need to remove your ceramic coating i would take advice ( if possible) from whoever applied it. You could try Methalated Spirits or similar but personally i would get advie from who applied it first.Does anyone know how to get stickers (angles mort etc) to stick on the van when it has had ceramic coating done, as I keep losing them.
If you run over a cyclist are you going to get out and stick them on and make them look dirty so it looks like they have been there all along? Meanwhile a cyclist is writhing on the floor with broken bones?I know this is not the answer you are looking for but if it were me and it was likely to damage my paintwork or overall finish I would be putting them in the glove box.
What is wingtape, and where do you get it from ?Stick a slightly bigger base of " Helicopter Wing tape" on the van,then stick the sign to that. Over sticking then with another layer of Wingtape is belt and braces.
Frame protection film is similar, it's clear semi sticky film. I used it on the back of our van for the same thing. Also handy for putting a protective layer over items like touch screens. Also used for our Crit Air sticker.What is wingtape, and where do you get it from ?
Thanks will try this.Frame protection film is similar, it's clear semi sticky film. I used it on the back of our van for the same thing. Also handy for putting a protective layer over items like touch screens. Also used for our Crit Air sticker.
https://www.ebay.co.uk/itm/22557848...pid=5339023013&customid=&toolid=10001&mkevt=1
Mike.
Thanks you lean something new every day.![]()
Nitto Wingtape
Southern Aero Supplies is an aircraft supply shop for GA & gliders. Pilot, engineer and flying club supply shop based at Membury Airfield just off the M4.www.southernaerosupplies.com
