PVC rear door stays.
worcester
Sunliving van
If your van converter has fitted rear windows and has done nothing to stop the doors opening to more than 90° here is what you can do.
Remove the lower interior door trims.
Buy new stays for about £15 each side(ebay). Simple job to remove and refit. Spring loaded stops will prevent door opening more than 90°.
Or open doors to 90° and mark the stay arm where the door mounted friction block buffers are. Remove complete stay from vehicle drill a 6mm hole through stay from top in line with the mark u made on the side. Insert 6mm bolt with 2 nuts above and 2 below stay. Refit.
Door will not now open past the point where your new bolts contact the friction block buffer.
Works for me.
