Graham of Madrid
- Oct 22, 2018
- 366
- 174
- Mc Louis Glamys 40
- Since 2019
Hello there !
In the past I had trouble attaching the jumbo connector to a Spanish propane gas bottle in the gas locker (lack of room) and it wasn’t possible to do this outside of the locker without removing the pigtail from the regulator as the pigtail was too short. I have to do this every time I change or check the contents of the gas bottle. Surely this is not good long term.
Can anyone tell me where I might get a longer pigtail (what is its technical name / description / spec) and is there a rubber seal or something I need to replace on the regulator end of the pigtail if I continue to use the short one ?
I’ve been careful not to over tighten the pigtail when re-attaching it to the regulator by only slightly nipping the brass fitting.
Your help appreciated. Thanks.
